guru1974 Posted January 29, 2012 Share #1 Posted January 29, 2012 Yes, I know i shouldnt have but i was tryn to squeeze every ounce of hp outta this car. So, is there an old standard setting for the screw or am i gonna have to get a CO meter? Link to comment https://www.classiczcars.com/topic/42101-air-fuel-mixture/ Share on other sites More sharing options...
240260280z Posted January 29, 2012 Share #2 Posted January 29, 2012 Go through this section and you should be all set.Fuel across the rpm range is determined by the needles shape. The screw for the jet height basically sets the point on the needle at idle. However there are many things to check:- cleanliness- free mechanical linkage (return springs, choke/jet drop)- synchronized linkage for both carbs- matched needles and needle height (where it is secured in piston)- matched jet depth- same piston rise/fall rates- no air leakshttp://www.classiczcars.com/forums/forumdisplay.php?140-SU-Carb-Technical-Articles Link to comment https://www.classiczcars.com/topic/42101-air-fuel-mixture/#findComment-379071 Share on other sites More sharing options...
guru1974 Posted January 29, 2012 Author Share #3 Posted January 29, 2012 oh yeah i forgot to mention i have the factory efi .........thats y i am embarassed as i found a section in the forum that says dnt touch . thanks for the quick response tho. Link to comment https://www.classiczcars.com/topic/42101-air-fuel-mixture/#findComment-379072 Share on other sites More sharing options...
240260280z Posted January 29, 2012 Share #4 Posted January 29, 2012 There is a reference called the EFI bible that you should read. It explains everything. Link to comment https://www.classiczcars.com/topic/42101-air-fuel-mixture/#findComment-379074 Share on other sites More sharing options...
guru1974 Posted January 29, 2012 Author Share #5 Posted January 29, 2012 Cool, sounds good. thnks for the info. Wish i would have just left the dang thing alone, but i gotta see wat it does for myself most times. Link to comment https://www.classiczcars.com/topic/42101-air-fuel-mixture/#findComment-379108 Share on other sites More sharing options...
FastWoman Posted January 29, 2012 Share #6 Posted January 29, 2012 Even after you set everything right with the old L-Jet EFI, you might find the mixture is still off. There are no intended adjustments, aside possibly for the idle mix screw at the bottom of the AFM. I don't find that it does much. You can also change the mixture by:-- adjusting the tension on the AFM clock spring -- described in an article on Blue's Atlantic Z site. I wouldn't use this for big adjustments. This only works for low to moderate throttle. If you're really cranking the engine, the AFM will be pegged out anyway, and for RPMs above 4500 I think the AFM is ignored anyway.-- adjusting the fuel pressure with an adjustable fuel pressure regulator. An adjustable FPR usually isn't as precise as Nissan's stock FPR, and it will not hold pressure after shutdown. You're also limited in your useful adjustment range. Again, you don't have a lot of latitude here, but the adjustment will work uniformly throughout all aspects of the EFI's operating range.-- wiring a potentiometer in series or in parallel with the coolant temp sensor to increase or decrease the resistance of that circuit, respectively. This will either richen or lean the mixture, respectively. This adjustment will impact the mixture the same way throughout all aspects of the EFI's operating range, but it will somewhat diminish the mixture accuracy during engine warm-up. Link to comment https://www.classiczcars.com/topic/42101-air-fuel-mixture/#findComment-379117 Share on other sites More sharing options...
