I am getting ready to polish an intake for my 72 240 and found the coolant tube that crosses between the the two manifolds is shot.As in plugged up bent and in general just jacked up. Does anyone know where i can find one? Or can I cap off the holes and not use coolant through the intake? Or can would hose barb fittings and heater hose work in there. Just looking for opinions on what would be best.
Thanks for any help
https://www.classiczcars.com/topic/42127-intake-manifold-coolant-tube/
Remove all the fittings and fill the holes with little freeze pugs with a little goop to hold'em in place. Chicks'll look in there and see something silver and go "OOOoooo". You can clean up all the "water around the block" stuff at the same time.
  • Who's Online   0 Members, 0 Anonymous, 1,210 Guests (See full list)
