Hey all . here is what I have going on . I just put back on rd after winter sleep and If i leave the headlight switch turned off ,all my electric works perfect . I turn the lights on and I loose my turnsignals and the interior signal indicator lights both stay on . My 4-way flasher works as new and when I engage the switch while the headlights are on , the interior signal lights will then cancel themselves . I have Dave Irwins headlights relay upgrade for two years now installed and I,m wondering is it a relay issue and how would I check that .
Thankz for any help
Chris
https://www.classiczcars.com/topic/42536-gremlin-lurking-under-hood/
First, inspect the ground wires around the steering column. After eliminating the ground as an issue, work your way though the different circuits one at a time with a voltmeter. Do that with the headlights off and on. I still think it's a bad ground somewhere.
  • Who's Online   1 Member, 0 Anonymous, 573 Guests (See full list)
