The d6k8-22 is a 1980 california model electronic distributor from a 280ZX, for both auto and manual shift trans.
It has 17 degrees mechanical advance and uses a vacuum advance with 30 degrees. (wow, that's heaps!)
That's pretty good Leon off the top of your head. ;)
Edited by ozconnection
https://www.classiczcars.com/topic/42554-dissy-d6k8-22/#findComment-383574
Booyah! LOL
I spend too much time on this stuff...
https://www.classiczcars.com/topic/42554-dissy-d6k8-22/#findComment-383582
great thanks for everbodys help ,is the vaccum advance of 30 degrees to much for a stock f54 block with dished pistons n47 head and su carbs? car runs great with no ping or noise.or would I be better with vaccum advance disconnected and run 17 degrees timming plus 17 degrees of mechanical to make total 34 degrees
https://www.classiczcars.com/topic/42554-dissy-d6k8-22/#findComment-383598
