I would recommend a close inspection of all the metal and apply rust treatments where needed (especially inside the box section structures and brake lines).
You may wish to spray penetrating solvent on any bolts that you plan to remove in the future.
You can also paint or spray white lithium grease on bolts,joints,metal that needs protection from rusting.
If you want a longer job, drain then drop the tank and inspect the vent hoses as well as the tank and sender and wiring.
You can also disassemble,inspect,lube and reassemble your rear brake cylinders and shoes/springs.
  • Who's Online   0 Members, 0 Anonymous, 1,543 Guests (See full list)
