installing sprocket/timing chain
hi everyone,
i replace my 240z(72) motor with a 280z motor from an 83. it was very powerful motor compare to my dying 240 motor. i use it for 1 day, and unluckily i burst a water hose(old) and the motor overheated. head gasket is broken. i replace it (my first time). everything went smoothly except when i am about to install the sprocket and timing chain. it just wont reach the cam. i lift the sprocket with the cherry picker it wont go, i use a crowbar to left it , nothing move, i turned the crank to check if i have a kink down the crank, nothing , it turns ok.
if you have done this before, or have an idea how i can install it without opening the whole front, please let me know.
thank you so much,
hf240z@yahoo.com
https://www.classiczcars.com/topic/4260-installing-sprockettiming-chain/
  • Who's Online   2 Members, 0 Anonymous, 1,505 Guests (See full list)
