OK, I finally got the sheets scanned, hopefully they display right.. The Dyno used is a DynoJet 248 Model 248 single drum.
More info on the day - Cool about 48 degrees and cloudy, which I'm sure helped
Uncorrected - what it pulled that day
SAE - what it should pull regardless of condidtions
Weber info:
DCOE 40's - fairly old - Made in Italy in top cover
Idle jets - 50F9
Main Jets - 130
Emulsion tubes - F11
Air Correctors - 180
Chokes - 30
Timing set at 33 degrees
Fuel - Super Unleaded
Edited by E-ticket
When I was at the dyno the operator had a choice of numbers- example SAE. I guess you could do a direct comparison to factory SAE numbers that way. I believe the dyno gas the ability to correct for atmospheric conditions to make thongs apples to apples
Corrected dyno numbers account for changes in temperature, pressure and humidity and are the numbers for a theoretical "standard" day. The only apples-to-apples comparison that can be made is if the cars run on the same dyno, utilizing the same correction standard.
  • Who's Online   1 Member, 0 Anonymous, 790 Guests (See full list)
