Can someone tell me the differance between the 240 and 260 engines ? hp? has anyone had any experience with these rebuilt engines from Datsun LLC in California,,completly rebuilt with head for 2k +shipping...seems like the way to go,, R AND R and no bull from local machine shops that dont work on these engines on a regular bases...or does anyone have a machine shop they use and are happy with in the White plains new york area... THANKS
https://www.classiczcars.com/topic/42691-engines/
The L24 and L26 are the same basic engine - however the L26 has a longer stroke. Minus all original emissions considerations - if you equipped either of them with the same head - the larger engine should produce more torque/HP than the smaller one.
I'd be looking for a shop close to home - to have an engine rebuilt. I'm sure there are plenty in New York - just talk to folks in the local clubs. If you have a 240Z with it's original engine - I'd have that one rebuilt and keep it with the car.
I would expect to pay around $3000.00 to have either L24/L26 properly rebuilt - if I took the engine to the rebuilder and picked it up when done. With good machine work, new parts needed, seal kits etc - you would have around $1800.00 in parts and labor - not counting the disassembly and re-assembly and time spent locating all the needed parts. Turn around for that work, at a good shop should be 3 to 4 weeks. {takes time to get all the parts assembled, the head/block scheduled in the machine shop etc}.
You really don't want to deal with a vendor that is out of state - unless they are one of the big names with outstanding reputations. Hard to sue someone in another state, or even recover any funds...just not worth it.
https://www.classiczcars.com/topic/42691-engines/#findComment-384850
