I've searched and found that GL-4 gear oil should be used in my transmission and everyone seems to be using redline oil for their transmissions. But I can't find any gear oil that is only GL-4. My question is can I use Valvoline 80w-90 gear oil even though on the back of the bottle it says, "Recommended for all hypoid differentials (conventional and limited slip) and manual transmissions where an API GL-4, GL-5 or MT-1 fluid is specified."
https://www.classiczcars.com/topic/42698-gl-4-gl-5-for-240z-tranny/
There is a little confusion here because oils that meet GL-5 supposedly eat yellow metal. I did a little searching on this about a year ago and it looks like there are either NO or VERY FEW oils that are GL-5 rated that still have this problem, and if memory serves any oil that is also rated GL-4 or MT-1 is good to go. I like SWEPCO 201, and I used to cut it 50/50 with ATF to make it a little thinner and get a faster shift. Works great in Nissan transmissions either way, and I use it straight in Nissan limited slips, no LSD additive required. Lots of people like Synchromesh, which is available through Pennzoil and a couple other distributors, and I think you can get it at GM dealers as well. Really though any good quality gear oil will do.
  • Who's Online   1 Member, 0 Anonymous, 1,275 Guests (See full list)
