Passing on my experience.
The clock was repaired in 1983 but always ran way fast after. Decided to adjust a month ago, but evidentially I broke it. :-(
Did some searching and found this place that specilizes in upgrades of old auto clocks.
Instrument Services, Inc
117 Main Street
Roscoe, Il 61073
email instrumentservices@frontier.com
www.ClocksandGauges.com
Cost was $150 plus shipping there of $13 and from there $15. Total of $178
They replace the inner workings with a quartz movement. They also restore the face, hands, and polish the lense face.Takes about two weeks. They call you when they are ready to work on your clock for your credit card , which is charged when they complete the work.
I give them 5 stars, for now I have a time keeping clock in the car.
Edited by ZCCOR#109
https://www.classiczcars.com/topic/42741-clock-repairrestore/
I think most people use Ron at Zclocks http://www.zclocks.com/. His current pricing is about the same, $149, but the return shipping is included. Ron does great work and restores the entire clock, including the case. He is also the only person I know that can repair the rare Z rally clocks.
-Mike
  • 1 year later...
For the Do-It- Yourself owners check out S30 posts on this topic contributed by CZCC member, EScanlon.
Enrique was trying to track down the reason for a little drift in timekeeping he had between his power supply and his car. He asked me about it, but I didn't have the opportunity to delve into the issue. My guess is that the non-quartz clock is just more sensitive to voltage. Doing a refurbishment like ZClocks goes to a quartz movement that is probably less sensitive to the voltage.
Shouldn't be... The non-quartz control board is shunt zener regulated. Unless you're trying to run it off a pair of D cells, it should be just fine. Even a 9V battery should power it just fine for quite a long time.
Of course the quartz movement could (should?) be more accurate, but not because of the input voltage variation.
