$10 Additional LED Break light
The thin wire is already covered in black braid, and I bundled it with the wire for the rear defrost. The I tucked the wire inside the roof trim and the rear quarter trim all the way to the brake bulb in the tail panel. You hardly see it at all. I gently spliced it into the brake bulb wires. It's just temp rigged in the photo, so you can see the wire still.
http://www.logisyscomputer.com/products.asp?PID=STRIP&DID=LED
they don't show the 12" strip but here is the link I figures out by part number: http://www.logisyscomputer.com/viewsku.asp?SKUID=LDS12RD&DID=LED
By the way, you can cut these to length if you get a longer one! They are peel and stick, but I "helped" mine with a spot of crazy glue at each end.
or here: http://www.axiontech.com/prdt_link.php?item=94434&PRICECOMPARISONSID=ubhgjkpp
Edited by cygnusx1
  • 1 month later...
  • Who's Online   3 Members, 0 Anonymous, 1,444 Guests (See full list)
