Posted March 28, 201213 yr comment_385558 I just replaced a '79 5-speed with a '77 or '78, 5-speed, and this one allows the shifter to go from 5th directly into reverse. All of my previous transmissions, all later models, do not allow this motion. Edited March 28, 201213 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/42772-do-early-5-speeds-have-a-reverse-lock-out/ Share on other sites More sharing options...
March 28, 201213 yr comment_385572 My ZX 5-speed had no lock-out. Link to comment https://www.classiczcars.com/forums/topic/42772-do-early-5-speeds-have-a-reverse-lock-out/#findComment-385572 Share on other sites More sharing options...
March 28, 201213 yr Author comment_385574 Interesting. I could have sworn that my '79 had the lock-out. I am certain that the early 80's 200SX trans that I used to have had one. Link to comment https://www.classiczcars.com/forums/topic/42772-do-early-5-speeds-have-a-reverse-lock-out/#findComment-385574 Share on other sites More sharing options...
March 28, 201213 yr comment_385578 Pretty sure it was a ZX and later thing, not sure what year though. My 80 transmission had it. Link to comment https://www.classiczcars.com/forums/topic/42772-do-early-5-speeds-have-a-reverse-lock-out/#findComment-385578 Share on other sites More sharing options...
March 29, 201213 yr Author comment_385579 My mistake, my prior trans was a 1980 with the taller 5th gearing, good for building boost. That must be why it had the lockout; not the same as the S30 units. Apparently the 77-79 had none, and are the same transmissions. 80 is a unique tall 5th gear ratio with a lock-out, and 81-83 are different ratio with slightly shorter 5th gear, and the lock-out for reverse.So I can stop wondering why the reverse lockout doesn't work in my 77-78 trans... Edited March 29, 201213 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/42772-do-early-5-speeds-have-a-reverse-lock-out/#findComment-385579 Share on other sites More sharing options...
