I removed more of the dash and fittings from the car over the weekend. I also had a play with a spare cluster surround I had to see how easy it was to remove the wood grain finish. As most of you are probably aware, underneath that wood grain trim is the raw aluminium finish used in the GTR. Obviously the same piece was used, it was simply covered for the non GTR models.
It turns out thinners or gun wash is very effective! I tested this on my spare piece and it worked a treat. The only common problem is a lot of pieces have corrosion "worms" in the finish. I'm not sure if this is a result of the trimming process or what. The first piece I tested was petty bad so I decided I'd make something similar to a mitre box and line the base with either 1500 wet and dry or 3M steel pad then pass the alloy through to get a new uniform brushed finish.
I decided I'd remove the second panel last night more carefully than the test piece so I wouldn't damage or bend the alloy. I tried using a heat gun but it's not fantastic. It looks like a contact adhesive is used on the back of the alloy panel to fix it to the plastic. I ended up pouring some gun wash in between the alloy and the plastic and then waited for it to dissolve the glue. Not great for the plastic but I do have a spare which I plan on spraying.
Once the alloy was off I make up a make shift bath with foil and left the piece if for about 30 mins or so.
Once the thinners does it's work the wood grain cover is reduced to a balloon like rubber and simply peels off. It's a bit tricky to get off the edges but with some care it all comes off.
The contact adhesive also peels off the back
Once all the glue and rubber is removed, if you are REALLY lucky you might fine a virtually perfect aluminium panel like I did. It's still a bit grubby in this pictures so I'll brush it with some more thinners tonight and give it a good scrub. It has some very minor corrosion spots but I'm not going to both fixing them, if anything we may try and clear it.
A word of advice, make sure your bath doesn't leak. My garage is going to smell like a spray shop for a while :ermm:
I removed the remainder of the stainless trim from the car last night with a heat gun. It was glued down real good which was a major pain in the arse. That's the entire outside of the car done now. I have sent most of the bright work away for straightening and polishing. Will post pics when it comes back.
It doesn't look like a whole lot has changed really but it's good progress. I'll gut the rest of the interior soon I reckon and have the parcel shelf and other trim pieces remade.
I'm waiting on some space to shift the car before I remove the engine and blast the car, I need it running to move from the garage. I may remove bonnet, boot and doors etc and start work on them before hand.
  • 3 weeks later...
Progress is a bit slow at this point, I've got stuff away being worked on which I'm hoping to pick up this week and some parts coming from Japan also.
I pulled the cluster and gauges from the car when the interior came out. I'm always amazed my how much dust I find and where I find it. I guess I have to remember the car is 37 years old, older than me! Anyhow I wanted to clean and service the lot, make sure that they were OK electronically and reset the ODO as the car is really being reborn, so it deserves 0 on the clock.
I've removed the clock on these as the GTR's had a 'Nissan' blanking plate instead of the clock. Hoping that should arrive this week.
Reset the back to 0, looking much cleaner now too.
I cut and polished up all the lenses, cleaned the housings, dials and needles, checked the circuit boards and components and then reassembled the lot. I'm trying to decide if I change the globes out for LED's or stick with bulbs for the warm glow they give. It's interesting how the bulb housings are painted in certain areas to restrict where the light shines. I think I'll have to play with this and see what looks right.
