I have a 1971 240Z, stock and original L24 with 1983 280ZX dizzy, E12-80 module, and MSD Blaster 2 coil, and no ballast resstor. I am installing a later model 3 wire tach. Do I need resistor inline with the wire from the coil? If so, what ohm/amperage is needed?
I appreciate any and all advice!
https://www.classiczcars.com/topic/42816-3-wire-tach-in-240z/
The inline resistor on the 75-78 280z's between the trigger terminal on the 3 wire tach and the (-) side of the coil is a 2200 ohm resistor (2.2K). 1/2 watt size should be plenty. I am using that resistor with my E12-80 module and that same tach and it works fine.
Edited by zKars
  • Who's Online   2 Members, 0 Anonymous, 1,503 Guests (See full list)
