I'm jealous of how much room you have to install the intake bolts. The mikuni short manifold is a total bitch. On the other hand I wouldn't have room for my cold air intake with that long of an intake .
That is a beautiful set- up and inspires me to get mine done.
Waiting on the UPS man!!!!!!
Well here is an update on the install.
I laid on the ground for about an hour last night with the electric fuel pump in one hand and the pump pre-filter in the other. I pondered how to get them in there safely and smartly so that the hoses are not too kinked, and it was as OEM as I could make it. I finally found away to route the darn fuel lines without disturbing any of the factory fittings, clamps, or hard lines. I am very pleased how this turned out.
Next I turned my attention to the electrical side. I really hate messing with wiring, but since I could not get any power to my rear green wire, AND I could not find where that particular wire surfaced again under the dash, I pulled off my center console (had to do that anyway, as I need to decide what I am going to do with my choke cables) Low and behold, I found this little jewel still taped up with factory blue datsun electrical tape and tucked away. Well I think it was from the factory. :)
It has a green wire, AND a black/white wire. The green wire acts weird when the key is turned and fluctuates a millivolt reading constantly. However, the black/white wire, which is 12V in darn near every other place on the car is a switched 12V supply here as well. Eureka!
I still need to run the wire to the pump in the most unobtrusive way I can. I would like to run it inside the car all the way to the back, but I may run it next to the factory fuel lines so I can keep it wire tired close to the tranny tunnel. We will see.
dhoneycutt,
Thanks very much. You should see it now. I spent an hour polishing it with some aluminum polish last night. Looks like chrome for the moment.
I purchased a 30" length of extruded aluminum tubing. It had a 1/2" hole through it. It was round on one side and square on the other. I cut it to be about the length of the valve cover, so I could use 90 deg bends to go around it. The brackets I made allow me to get access to the valve cover bolts without taking off the fuel rail. I also used longer studs in the intake so I could remove the fuel rail without taking off torque from the intake.
I used the square side to attach my carb fittings (drilled and tapped 3/8" NPT using Russell -AN fittings) I thrn drilled and tapped a 1/8" NPT for the autometer fuel gauge after the third carburetor. I tapped Both ends of the line to accept 3/8" NPT. Right now the front end has an NPT fitting to a 90 deg bend that goes to the fuel regulator. I have since fabricated a support bracket to hold the fuel line secure so it is not dangling in the front of the engine. The back of the fuel rail is plugged, but I think I may run a return line in the future to factory spot next to the alternator. I can run a -4 AN line with a restricter in it to give the pump something to push against. This will keep the fuel circulating. So far I have not altered the car in any way permanently, and can go back to SU's in an afternoon. My goal is to not cut, chop, or bend anything I do not have to.
I may remove the fuel rail one more time to manufacture a way to attach return springs... but I have not decided on that yet. My goal is to be running before the 21'st, which is a great car show I went to 2 years ago and got beat by an old celica.. which was a shame!
No it is there bud, but I cannot find where that wire is IN THE CABIN. I know the rear wiring harness comes into view again around the passenger door. I have no idea where that wire goes inside the car is my issue. It is not getting any power that is for sure. I know the green wire is suppose to get 12V, but unless I find it in the cabin and feed it some power, I will have to run a wire.
Please! more pictures!!! :classic:
Where did you purchase the extruded aluminum tubing? I was thinking of something like this but had not seen it done on non-fuel injected engines before. ( I know, I live a very sheltered life;))
I went to ebay motors and typed in the search engine "universal fuel rail"
Got more hits than I care to mention...
http://motors.shop.ebay.com/i.html?_from=R40&_trksid=p3841.m570.l1313&_nkw=universal+fuel+rail&_sacat=
I have not wired in a relay at all. I have seen the green wire in the back, and I do not care how it gets back there, but I have NO idea where it is in the cabin. After it goes in the chassis in the back it is GONE. I guess I could start pulling interior bits off to find it, but I really do not want to!
If I knew where it was, I could tap into it. I still want to wire in a relay, but I will worry about that after I get the car running.
Under the glove box corner of the cabin. I think it is a seperate wire plug and it's green, just fish around all those wire bundles under the dash by the glove box, you will find it.
I might wire my relay in tomorrow and I will take pics if I do.
The UPS man showed up today with a Mikuni install kit:)
Edited by madkaw
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
