Metal elbow noodle brazed in. These are the one of the early sets of triples used on the #33 BSR 240 and you can see where they tapered bored them out to 50mm.
The direct stream of 114 octane means after you lift and then get on the throttle a nice flame comes out the twin exhaust trumpets.
It idles quite nicely, big cam, twin trumpets, a rich rumble.
There are two issues. It doesn't generate enough vacuum, so the first fix was an electric vac pump for a year and then last winter Wilwood pedals with MCs which cured that issue and two, idling or just driving back in to the garage from the track will leave a nice deposit on the plugs and top of the pistons.
After a run at WOT here's the color of the exhaust...
  • 1 month later...
That's about how mine looks after a highway drive on my Z with Mikuni's.
On my Z with SU's, I can't get that color on the exhaust.
