I have a late model 280zx 5speed and a 4:11 diff in my 240z and I'd like to correct the speedometer error (~10% high). A 20-tooth (red) pinion is needed but I'm having difficulty finding one. Courtesy only stocks up to the 19-tooth, which I now have. Any suggestions where to obtain one? Are there any other issues I should be aware of besides having to drain the trans first?
https://www.classiczcars.com/topic/43014-280zx-speedometer-pinion-gear-swap/
A place to buy:
http://www.nissanpartszone.com/parts/nissan-pinion-speedo~32703-78104.html
Source:
http://www.classiczcars.com/forums/attachment.php?attachmentid=1978&d=1051876395
I believe HS30-H provided the scanned photo of the part numbers while Leon found the site to purchase them. I have no personal experience buying from them, but I wouldn't hesitate to. They seem legit.
A place to buy:
Source:
You are correct! I got a 21T and it was something like $25 shipped.
Ironhelix, I am hoping you bought the speedo sleeve assy. for 20 to 23 teeth pinion gears, part #32707-66300, otherwise will not fit in the smaller pinion gear housing and the gears will bind. Read what it says about the larger tooth gears in ggretc's post above; http://www.classiczcars.com/forums/attachment.php?attachmentid=1978&d=1051876395. The larger pinion gears will fit in the pinion gear housing for the smaller 19 tooth or less gears, but the teeth will not line up correctly in the tranny.
Edited by duffman
  • Who's Online   0 Members, 0 Anonymous, 1,527 Guests (See full list)
