Everything worked before I plugged in the LED taillights and flasher and everything works after I changed back. Guess I'll wait 'til Dave gets back from MSA to ask more. Thanks for the thoughts.
Was everything on the "new" car functioning before you attempted the swap? I've found that a bad hazard switch, or one that is not in the correct position can wreak havoc on the turn signal system.
