Could I use this in my transmission as well as differential on a '77 5spd? I know everybody runs Redline but this has to be close in quality and is a 1/3rd of the price. http://www.walmart.com/ip/Super-Tech-75W-90-Syn-Blend-Gear-Oil-1-Quart/16795248
Differential yes, transmission NO!!!
GL-5 oils have too much sulfur with will destroy the brass/bronze synchronizers in the transmission. The transmission requires GL-4 gear oil. Redline MT-90 works, and there is a Penzoil product that will work. Look for a reference to "safe for Yellow Metals" in the description on the container.
If you don't have a Redline Dealer and you don't want to order it - - you can also use Royal Purple Max-Gear. Many of the National auto parts stores carry it in local stock. It is a few more bucks - but I don't like waiting of stuff to be shipped..
http://www.royalpurple.com/product-categories/automotive/#!max-gear
GL-4 & GL-5 .. safe for yellow metals.. etc.
FWIW
Carl B.
  • Who's Online   1 Member, 0 Anonymous, 1,481 Guests (See full list)
