Getting ready to start the car in the next week or so. I want to give the engine its best shot to fire up on the first dozen or so cranks. That said, what's the best way to prime the fuel system with my (new) mechanical pump? Can I remove the valve cover and actuate the pump lever by hand until fuel makes its way to the carbs? Or is there a better/easier way?
Plan to do that, but won't the car just stumble and die until the lines, pump and fuel filter are filled? The objective is to avoid any break in fuel supply.
Nope. It will idle for an unexpectedly long amount of time on just the bowls. With the engine running, the pump will get the fuel moving very quickly.
I've done this and can vouch for the claim above. I didn't actually time it with a stopwatch or anything, but it was at least thirty seconds of idling, and maybe as much as a minute before the engine started misfiring.
If you haven't sucked fuel through the pump by then, you've got other issues.
Oh yeah, and if your idling engine sucks the bowls dry in less than twenty seconds, then you've got other issues as well. :bulb:
Now to figure out how to apply the fuel tank sealer without clogging the tank intake screen/sock (if there is one)... Sigh. Onward.
Not much to worry about. There is no screen / sock, just open tubes. The pick up tube is about 3/4 inch off of the bottom of the tank, the return is further up. With a mirror on a stick, illumination through the sender hole and looking through the filler hole you can see the tubes over the baffle. When the sealer was curing I made sure and ran compressed air and a thick wire through each tube, just to make sure.
The longer the cure time on your tank, the better.
Bonzi Lon
POR-15 recommends 4 days before putting fuel in, so I'm going to give it that. Good to know about the lack of a screen/sock as well. I like the thick wire + compressed air trick. How long did you leave the compressed air hooked up?
Thanks!
Right; but you didn't leave the compressed air hooked up the whole time, did you? I was just thinking about leaving the wires in the whole time, as you suggested, but only blowing compressed air in for the first, say, 6-7 hours or so.
