For these motors, most HP is in the head. A header and intake will give you a little but head work and cam is what you will have to do.
A good coated header will set you back $300 to $1000
A good efi intake will cost $300-$600
You can upgrade the EFI and tune for more HP but that is more complex and $$$$.
The only other way for easy HP is to swap out the motor for a 280zx turbo motor.
The cheapest horsepower is simply to press further on the pedal and run ~1,000 to 2,000 rpms above where you normally drive.
Try some new plugs, 8mm wires, performance coil (remove the ballast resistor), run premium fuel, adjust the timing and adjust the valves. After that you can try a K&N type air filter, header and 2.5" exhaust. And remember that reducing weight is like adding horsepower. The '78 Z has some pretty big bumpers...
Chuck
The only thing you can do is give it an extremely accurate tune up .
Nothing will give it more power the way you describe you want to do this .
Fresh filters , oil , plugs, wires , cap + rotor etc. might free up something .
Fresh gas with the right octane helps too .
If your passenger weighs more than 100 pounds , open the door and give her a boot ( kidding ) .
More horsepower and tourque ( Canadian , eh ) are achieved by a performance rebuild and planning , not ''bolt on'' stuff. ;)
In other words cbuszesk in post 6 says it too .
Edited by Unkle
Exactly! Go through the FSM and give every system a tune up. The results will far exceed those from throwing bolt-on parts at your engine.
Unkle,
Is that 100 pounds Canadian or American? I think I'd allow up to about 120 lbs if properly proportioned.
Question about octane--if a car is not pinging on low or mid grade, will a higher octane really give more power?
Answer: a resounding no.
A bump in octane will help if and only if you have pre-ignition or detonation at MBT timing.
Unkle,
LOL OK 120 then . On the octane statement , I did say the correct(right) octane ( for the motor's current setup ) , not higher rating .
Edited by Unkle
  • Who's Online   1 Member, 0 Anonymous, 1,445 Guests (See full list)
