harnesses,wires,etc. holddowns
I can't remember ever seeing anything about these. I don't know what their called. they are the bendable metal with rubber coverings that hold down the harnesses,wires. I cut mine out with a spot weld cutter and was going to redo the rubber. Can you buy or make the whole piece? thank you, TimsZ
https://www.classiczcars.com/topic/43197-harnesseswiresetc-holddowns/
Im not sure if you can still buy them but you could cut some new strips of metal and purchase a product called liquid rubber which is used to dip the ends of tools in to create a handle and put that on the end of the strips after you spot weld them back to the car. You should be able to find that product at a local hardware store or automotive center. Richard.
