It isn't so much a matter of whether it will seal well or not at this point it undoubtedly would. It is whether or not you'll have to literally CRUSH it and/or if the thickness is such that it will push against the fender so much as to affect the "look" of the panel by pressing from below.
This is critical, because you don't want to stress the fender when you mount it and THEN discover that it tweaked the fender out of shape.
Foam crushes down to a very thin layer, and only if you used a very hard-closed cell foam would you affect the fender outline.
FWIW
E
https://www.classiczcars.com/topic/43233-will-this-work/#findComment-390266
  • Who's Online   2 Members, 0 Anonymous, 1,478 Guests (See full list)
