Hey everyone,
I know you guys are all about keeping things lightly modified or stock.
2 pretty straight questions for what could become a large modification (just to get me started).
I was told the engine in my 71 240z is a 260z engine/transmission. Are there any numbers on the block that would tell me what the truth is? Same for the transmission?
If it is a 260z, can I bore it to make a 280Z engine out of it (since a 280 is a bored 260, this makes sense, unless i'm missing something)?
The end result I want is a carbureted 280Z that runs well and fast with a 5 speed transmission, for as cheap as i can do it (i'm pretty good with a wrench, dad welds, need to hire boring/milling)
Thanks!!
https://www.classiczcars.com/topic/43295-build-a-260z/
