Okay guys, i'm getting tired and can't think straight-as well as second guessing myself.
The rear main seal gets installed with the flat part(face) of the seal facing me or the other way around. I am second guessing myself since I have had two leak.
I just installed a speedi sleeve for a new surface on the crank, but now I have somehow got myself confused as which direction the seal faces.
God I'm getting old I guess
https://www.classiczcars.com/topic/43306-rear-main-seal-orientation/
Don't forget to oil the lips of the seal.....and yes it should be flush with the block unless you have a previous groove in the crank journal, then it should be say .030 inches from flush to contact a clean surface.
Edited by Diseazd
Well I'm probably a 1/16" from being flush, which I can't see as being a problem because the hole in cover plate between the engine and tranny is slightly bigger to fit outside the seal. As far as riding a new surface, i installed a Speedi sleeve so the whole surface is new.
I got to say I'm a bit anxious about all this---BUT, BUT
I do believe I will better off because I do think I installed the last seal BACKWARDS:stupid::stupid:
I can't believe I did that, but I will have to fess-up.
I will use the excuse that I was under the car last time and under durress--wizz poor I know.
  • Who's Online   2 Members, 0 Anonymous, 1,493 Guests (See full list)
