240z inner left side tie rod replacement?
This is a well known problem with supply. Best solution is to get a new right inner and outer and put them on the left side. This is the solution of choice for many previously discussed here.
Yes, 280 is the same as 240, up to 78. There are other solutions to adapt other tie rods to our cars documented on hybridz.org, but nothing simple.
so the mechanic says right side won't work because of the threading....I'll keep searching here for why not....cheers
are there any more parts to buy besides the right side inner and right side outer to replace on the left side?
Edited by bounce
  • Who's Online   2 Members, 0 Anonymous, 1,503 Guests (See full list)
