My cylinder head has the square exhaust ports with the steel liners. Is there any advantage to removing them, and how do you get them out? I was thinking that they might be an unnecessary restriction, and removing them would improve exhaust flow.
Also,
How would you recommend matching the exhaust manifold to the exhaust ports? the only thing I can think of is to use the gasket or clear plastic and compare and compromise.
thxZ
https://www.classiczcars.com/topic/43378-removing-exhaust-port-liners/
To add to Blue's comment, I've never seen an attempt to remove those that didn't look bad. (Read as ruined the head.) The ports that have the liners are not the same size/shape as the real square ports, and trying to make them match the manifold is a major PITA.
mill the exhaust valve guides flush with the roof of the runner.
Is that a big improvement, or a small one? At this point, I might rather prefer to just get the engine back together and in the car, than ask the engine guy to start another 'project.'
BTW- it's an N47 head and N47 intake, and stock exhaust manifold..
thxZ
Edited by TomoHawk
  • Who's Online   2 Members, 0 Anonymous, 1,339 Guests (See full list)
