1970 Datsun 240z FRONT big brake kits/swap HELP!
hi i have just acquired some calipers from a 1995 Toyota 4Runner "s13wb" marked calipers, can any one help me figure out which rotors, spacers, or any modifications in order to have these calipers function properly? i have heard you can use rotors off a 1984 300zx 4lug but they did not mention anything about spacers or back plate trimming.
any feed back would be much appreciated, thank you ;]
Edited by jungo93
The best advice I can give you is go to HybridZ and do a search for brake jobs. There is a sticky there that outlines the entire brake swap caliper/master cylinder combo you will need.
It will save you a ton of time and money
Go here and read up: http://forums.hybridz.org/index.php/topic/39435-help-what-brake-options-are-available-for-s30-z-cars/
And the S13W caliper requires a rotor 25mm wide. Finding a 4 lug rotor that wide is a challenge. The more commonly used S12W caliper requires a 22mm caliper which works with the readily available 300ZX rotor.
  • 1 month later...
