The mounts won't work due to the difference in the glasses. The Sentra mirrors have the stem type adjustment levers which I had to cut off. I've made a stiff-paper mock up of the conceived bracket for a fabricator to use as either a pattern or design concept. I should have the car back from Doug on Friday. I'll pm you with my address.
