Yes that would be great. Not sure if these are exactly the same. Need the orange front RH version. I have the light harness coming to the light but they just are bare leads at the light actual connector at the engine harness side and I am not sure exactly how they connect to the back of the actual light. So given this the entire assembly may be best.
You have the lense, chrome trim and rubber, right? You need just the metal housing with socket, wires and plug? If you can show me a picture of the plug(s) from the engine harness I'll see if I have what you need. I have a several but need to make sure that I have one with the correct connector(s).
Chuck
No. I have nothing but the harness from the engine harness to two ended wires (which I assume go through a rubber boot into a complete light assembly). Nothing on them and nothing after that. This may mean that I need the complete assembly shown in the link a few posts ago.
May be able to splice the two ended wires into something but not really sure.
Assume at this point I have nothing.
Thanks for checking.
  • Who's Online   2 Members, 0 Anonymous, 1,172 Guests (See full list)
