I did this procedure on a early model 260z but i think your shocks might be the same. The front was pretty easy, just unbolt and remove. The rear.. I had to remove the fuel tank to make enough room to pull them back behind the body.
I dropped the tank and unbolted all the bolts but I couldn't pull the shocks out. The tip was too big to go through the hole.
  • Who's Online   2 Members, 0 Anonymous, 1,369 Guests (See full list)
