I intended on leaving an 1/8" sticking out and let that plate and the flywheel pull it down to mate with them. When I got through installing the main caps this is what I had, it went beyond the block surface. Will this be problem? Now would be a good time to correct it IMOP. Thanks for any replies. post-24724-14150819160333_thumb.jpg
https://www.classiczcars.com/topic/43486-is-this-ok/
Are you talking about the seals? Isn't the excess trimmed off? Here's a summary from the Monroe book -
Put silicone sealant in side-seal groove
Install cap and tap in until 1/8" from bottom
Oil side seals and insert in groove, push to bottom of channel
Snug cap bolts
Insert nails, press or tap down until flush
Trim ends of seals, leaving 1/16"
Don't know if that helps but it's in the book, but with more detail
https://www.classiczcars.com/topic/43486-is-this-ok/#findComment-392641
  • Who's Online   2 Members, 0 Anonymous, 1,391 Guests (See full list)
