My header install project has turned in to a "while you are at it" marathon. My car still had its original PCV hose and it was in a pretty sad state. Upon removing it I found lot of little bit black dry flakes and bits in the hose. Upon further inspection I dug out quite a bit of gas/oil gun from the PCV tube on the engine. I sprayed carb cleaner to brake it up and then used my screwdriver to rake it out. Once I got all I could I used my shop vac to suck out what else might have been loose. Is this normal for these cars? I plan on replaceing the PCV hose and PCV valve. Should I be looking at anything else while I am there?
https://www.classiczcars.com/topic/43497-pcv-tube-gunk/
