Slycooperr53 Posted June 11, 2012 Share #1 Posted June 11, 2012 hey guys, i just bought a project z car. im in the process of fixing the clutch. i get fluid from the master to the slave cylinder but its just not disengaging the clutch, and the pedal feels ultra light like theres no pressure. do you think i need a new slave cylinder? or can i fix the one thats on there?thanks guys! Link to comment https://www.classiczcars.com/topic/43505-74-260z-clutch-problem/ Share on other sites More sharing options...
rocketdog Posted June 12, 2012 Share #2 Posted June 12, 2012 Did you bleed the line? A couple of air bubbles will compress easily and give you the feel you are getting, plus the clutch won't disengage. I installed a new master a couple of years ago. Bleeding is a PITA if alone.....get someone to help and it will go fast. Link to comment https://www.classiczcars.com/topic/43505-74-260z-clutch-problem/#findComment-392765 Share on other sites More sharing options...
Slycooperr53 Posted June 12, 2012 Author Share #3 Posted June 12, 2012 Did you bleed the line? A couple of air bubbles will compress easily and give you the feel you are getting, plus the clutch won't disengage. I installed a new master a couple of years ago. Bleeding is a PITA if alone.....get someone to help and it will go fast.i bled the lines by myself. ill get a friend to help me out tomorrow see if that helps it. thanks! Link to comment https://www.classiczcars.com/topic/43505-74-260z-clutch-problem/#findComment-392766 Share on other sites More sharing options...
olzed Posted June 12, 2012 Share #4 Posted June 12, 2012 Yep. Gotta get the air out. Link to comment https://www.classiczcars.com/topic/43505-74-260z-clutch-problem/#findComment-392770 Share on other sites More sharing options...
