Site Updates this Weekend ×
Turning over but will not start 1973 240z
It may be the case of a broken connector! I have had two occassions where a female connector on an ignition wire from the coil to the distributor has broken due to age. They are hard to spot because the break inside the outer shield. You should be able to isolate to see if you have spark at the points and or spark plugs. If you have spark then it is fuel related. Good luck in your search.
You can't expect to get accurate help with such a vague description. You write a post like we all live next door and have seen your car and had a beer with you.
History of car?
Spark plugs look good, distributor looks good(what does that mean)-- are they putting out spark?
Fuel getting to the carbs?
Did you just do something to the car, or you just woke up and the car didn't run.
Doesn't fire up? Is it firing at all? Did it run before? Fire one up!
You see-we are doing a lot of guessing here-help us help you.
1973 Datsun 240z Brand new coil and checked the spark plugs they are in good condition. Checked the distributor looks good and new fuel pump and filter. Not sure what to do it turns over but will not fire up what should I do?
http://www.classiczcars.com/forums/thread46526.html
Perhaps the moderator will combine or delete some of his threads. He may not quite understand how the forum works. But yes He should give up a little more info if he wants help, But I do understand what it is like to be in a pickle.
Check for spark.
Edited by grantf
Thanks for the suggestions Zulaytr was correct and was able to isolate and fix the problem and sorry about all the threads I am new and thought I posted to the wrong thing and made new one and I am trying to figure out how to delete
  • Who's Online   2 Members, 0 Anonymous, 957 Guests (See full list)
