Jim, did you use the poly TC bushings as they came in the set in front and back of the mount? If so, start by replacing the backs with rubber and leave the fronts poly. If you still have them, you can use old worn out ones as long as they aren't in terrible shape.
Jeff,
Thanks for the tip. Yes, all were replaced at the same time. I'll attack it piecemeal with the T/C bushings first as you suggest.
Jim
  • Who's Online   1 Member, 0 Anonymous, 1,346 Guests (See full list)
