I'm suspecting it's even worse than you imagine... From your other thread, you set the needle depth using the "jet-push-piston-home" technique (which isn't the right method BTW) and ran the car like that with no turns down on the nozzle?
If that's the case, then that means you were actually idling the car with the needle shoulder pretty much resting on top of the nozzle. The only reason the car even idled at all was because the needle shoulder was mostly capping the nozzle hole. The tapered part of the needle wasn't metering the the orifice... The shoulder was. LOL
I'm gonna check the fiche to see if all years call for the same nozzle P/N.
  • 1 month later...
