Am replacing struts with kyb units. The kyb web site says do not add fluid to the strut tube. Other tips say add oil. Advice please. JB
Can you give me the direct URL - that shows KYB saying not to add oil to the strut tube? I can't seem to find it on their sight?
thanks,
Carl B.
https://www.classiczcars.com/topic/43909-struts/#findComment-396766
Carl
Can't resist a good hunt.
http://www.kyb.com/service/installationtips/installationtip08.php
"When installing a KYB strut cartridge do not put any water, oil or any other liquids inside of the strut housing. Any existing fluid should be removed from the housing before installing the new cartridge. KYB cartridges are designed and engineered to operate without any additional liquids."
Dang, I was planning on smuggling scotch inside my strut tubes... So much for that plan....
Edited by zKars
https://www.classiczcars.com/topic/43909-struts/#findComment-396780
The original rationale for a bit of oil in the tube was to aid heat transfer so that the insert would run cooler. Based on that, if KYB says they don't need the oil, so be it. No oil should be fine. But other than the mess to deal with next time, I don't see the harm in adding oil either.
https://www.classiczcars.com/topic/43909-struts/#findComment-396797
  • Who's Online   0 Members, 0 Anonymous, 1,527 Guests (See full list)
