Cams and Rockers should to be worn in together. You don't want to combine a used cam with a different set of used rockers - the wear patterns will not match and you will get excessive wear. If you swap in a used cam - use the same rockers used with that cam, on the same lobs. Number them and don't mix them up. Otherwise you can have a set of used rockers resurfaced or buy new rockers {EXPENSIVE} to use with the used cam in a different head.
FWIW,
Carl B.
https://www.classiczcars.com/topic/43982-cam-question/#findComment-397495
  • Who's Online   2 Members, 0 Anonymous, 1,381 Guests (See full list)
