Site going down soon for upgrades ×
Hello Again
at last after months of trying , 2 fuel pumps, and a lot of cuts on my hand, i got my beauty running.
HOWEVER...
the idle is really high(the little pron to adjust the idle is not responding at all), the gauges are not working, and the side marks
and tail light are not working,
what did i do to make this chain reaction of failing electrical issues?
it really doesn't make any sense!!
BTW, this is all i did to make the car run again
clean fuel tank
replace rubber fuel lines
replace fuel filter
put a filter between fuel tank and pump
new fuel pump(255lph)
new injector connectors
replace the AMF
replace the thermostat enclosure
new thermotime
new temp sender
new temp sensor
new NGK spark wires
i have two ECU , and when i use either one of them the car starts
as you guys can see i don't see where i messed up, please let me know your thoughts
thanks again to all for the help!:classic:
https://www.classiczcars.com/topic/44010-endless-as-alwaysi-love-it/
Are you talking about the lights on the gauges or the gauges themselves?
If it's the lights, they are on the same circuit as the running lights. Look for damage to the green wire with yellow stripe in your steering column.
If it's the gauges themselves, check your fusible links.
