Site going down soon for upgrades ×
I've searched some, will search more, but am asking as well.
77 280, had the trans changed from 4 speed to 5 speed. New clutch, pressure plate, and slave. The problem is when the clutch is depressed, the push rod to the fork comes out so far it binds and then often falls out. My guess is that the collar for the throw out bearing is the short one and it should be the long one? Any thoughts, experiences? I really don't want to have it taken apart if it doesn't need to be, but then again..........
Thanks!
Leonard
https://www.classiczcars.com/topic/44053-clutch-slave-push-rod-problem/
I had the same thing happen when I replaced the clutch on my car. slave rod kept coming out the end of the slave cylinder. after some reading on here, i came to the same conclusion you did about the throw out bearing length. my fix was to cut the slave rod at an angle and weld it back together, slightly rotated to lengthen the rod. I haven't had any problems with it since. there was some suggestion of an adjustable slave cylinder like what is on the 240z, but for the 280z, (do some searching on here, Thread is not that old) but i did not look into it much, as i had already fixed mine in the way described above.
