ok z running like a time bomb and trans is really sticky
silvey19k, the symptoms you are talking about is exactly what my car did for about 3 weeks before the master cylinder for the clutch went bad. I am going to replace all the parts the master the slave and the hose on the car this weekend.
You can see the discussion in this thread. Here
Hard 2 shift = clutch not fully disengaging. IS typically a lot worse on reverse and can cause grinding. Throw a new slave cylinder at it for $20 or less, bleed it good, 20 minute job tops, and if that still doesn't fix it, rebuild your master.
ok sweet im having the shop bleed it to see whats up while they have it for the ajustment and broken cam tower bolt. and if the shop cant get it buy a quick bleed then ill just replace the slave and master might as well since im in there right. im going to be going to school for automotive but i need my skill ti catch up with this z its a diffrent animal then your b18 honda or chevy v8 the basics are the same but the l28 seems to want its own thing.
Edited by silvey19k
  • Who's Online   1 Member, 0 Anonymous, 1,357 Guests (See full list)
