Hi all, I recently acquired a '73 with a '71 su carbs. It has been garaged for the last 25 years. I took out the gas tank and give it a good clean. Changed all the fuel, coolant hoses, and new spark plugs. I took out both domes to give them a good cleaning. The front piston of the carb travel less than the back. Aren't they suppose to travel the same distance when you rev the engine? The pistons travel freely up and down so no binding. I put sae 5w20 for damper oil. It can rev 6000+ rpm, but when I put it in 1st gear, the engine is very sluggish and dies eventually, the compression is good. Any suggestion would be appreciated, and if you know a good mechanic in the los angeles/orange county area, please let me know. tks in advance.
https://www.classiczcars.com/topic/44158-car-is-sluggish/
Have you performed a complete tune-up? If the valves are not adjusted properly and the carbs synchronized the 2 carbs won't have even air flow which would result in different piston heights. Also, a vacuum leak might cause similar problems as well.
https://www.classiczcars.com/topic/44158-car-is-sluggish/#findComment-399301
A friend of mine was having some issues like this one.
We fought with dizzy to setup timing accordingly with no good results.
At the end, the car died on the road; the alternator wires were corroded. they did not provide enough energy to the coil to create a spark under load. My friend had to destroy the plastic cover of the alternator to access the corroded area. Without destroying the alternator, it might be worth a check ;)
Edited by Lazeum
https://www.classiczcars.com/topic/44158-car-is-sluggish/#findComment-399399
The front suction piston opens 1/2 and back piston opens fully when revving. Now I swapped the front piston to the back one.
The front one now opens all while the back one opens 1/2. The piston that opens 1/2 now is doing the same thing after swap. The piston looks clean and the needle is good and straight. The gas floats are the same on both carbs. Is this a bad piston? tks
https://www.classiczcars.com/topic/44158-car-is-sluggish/#findComment-399460
There are many variables that could cause this symptom. If you push the pistons up by hand (engine off) do they move freely and drop by themselves to the bottom? Do they fall at the same rate? Do both carbs have the spring installed? Are the springs that same (free length, wire size, and coil diameter)?
https://www.classiczcars.com/topic/44158-car-is-sluggish/#findComment-399514
