When i go over the little reflectors on the road moving into the left lane the back left side always has a sort of popping sound, almost like metal hitting metal, or if the strut was dead... I replaced the struts and still have the same sound, any thoughts on what it could be?
https://www.classiczcars.com/topic/44166-left-rear-popping-sound/
Noises carry on these cars badly. Did you make sure the gland nut screwed down hard against the strut? Sometimes the supplied nuts are quite right and the threads bottom out before securing the strut . I had to use a washer on top of the strut to shim the gland nut.
Get your wrenches out and check torque on everything under your car
Good luck
This is my first thought as well. Make sure your gland nuts are tight and show a thread or two. The gland nut should not be snug with the top of the strut tube. A loose or improperly tightened gland nut would mean your insert is bouncing around the strut housing, hence the click.
  • Who's Online   0 Members, 0 Anonymous, 1,290 Guests (See full list)
