i think i found my problem. the ignition switch has some damage to the contacts and the blue wire leading from the switch to the fuseblock is partially melted! i'm ordering the electrical part on the back of the switch and maybe a new ignition switch as well. i will also repair the blue wire and seperate it from the others and see if that solves my problem.
https://www.classiczcars.com/topic/4431-engine-dies/?page=2#findComment-31005
