Site going down soon for upgrades ×
Ok I did mess with the ajust ments and its still hard to shift but then it will want to go back to shifting hard and grinding I replaced everything but the hose. Ill put that on tomorrow but I put grease where the shifter is under the boot. But I need some guidance.
Blue your my boy LOL. I ran the ajustments to where they are supposed to be and no. dice just a interment thing if I put the master where its Suppose to be can't shift and the peddle ill get some slip. I'm wondering if I should do a clutch and get the ajust done. I have 67xxx original miles on the devil.
It seems like the throw on the slave is not enough. You should be able to have a friend press the clutch pedal and you can watch it move by simply looking down through the engine compartment next to the battery. I think the throw on my 77 280z was ~ 35mm of movement (~1.4").Check this then report back to the post.
