you should search for EFI and ITB. The VicZcar has a great write up. There are also bolt-on solutions from japan. If you must know, you need ITB, manifold, injectors, stand alone etc.
it will cost WAYYY more than a set of mikunis with a Kameari manifold.
https://www.classiczcars.com/topic/44500-itb-info-needed/#findComment-402561
