5150 will Posted September 27, 2012 Share #1 Posted September 27, 2012 I'm wondering if I can use the GM module on an '83 zx distributor? Link to comment https://www.classiczcars.com/topic/44519-gm-hei-on-an-83-zx-distributor/ Share on other sites More sharing options...
Zed Head Posted September 27, 2012 Share #2 Posted September 27, 2012 Should work. You'll need to extend the wires from the magnetic pickup coil in the distributor to reach the G and W terminals on the module, and figure out which one is positive and which negative. And cover the hole on the side of the distributor, where the E12 module used to be. Link to comment https://www.classiczcars.com/topic/44519-gm-hei-on-an-83-zx-distributor/#findComment-402724 Share on other sites More sharing options...
5150 will Posted September 27, 2012 Author Share #3 Posted September 27, 2012 I was reading through some posts regarding this, but wasn't sure if it would fly on the '83 dist due to having the E12 92 module. I'm just looking to try and avoid the expense of the E12 80 if possible Link to comment https://www.classiczcars.com/topic/44519-gm-hei-on-an-83-zx-distributor/#findComment-402725 Share on other sites More sharing options...
Walter Moore Posted September 28, 2012 Share #4 Posted September 28, 2012 The mechanical part of the distributor is basically the same regardless of the ignition module. The Vacuum advance changes from year to year. I modified my breaker plate to limit the vacuum advance to 17 degrees at the crank, but most people just disable it.I have a chart on the site showing the different distributors that shipped, but the only breaker plate available from the dealers is the one for the 83. (As of a few years ago.) Link to comment https://www.classiczcars.com/topic/44519-gm-hei-on-an-83-zx-distributor/#findComment-402802 Share on other sites More sharing options...
5150 will Posted September 28, 2012 Author Share #5 Posted September 28, 2012 Thanks a bunch guys. I was fairly certain it would work, but wanted to be certain since it did come with the other module. Link to comment https://www.classiczcars.com/topic/44519-gm-hei-on-an-83-zx-distributor/#findComment-402805 Share on other sites More sharing options...
