If originality is important to you, I have dealt with an ebayer who is in Canada just north of you. His ebay ID is "nikkibid1972", seems to have, or is able to find, early hardware, and I thought he had sold these screws on ebay at one time. Good luck.
Dan
Edited by AZ-240z
You're correct, good catch. The center console screw are M6x1.0, the heater bezel screw are M4x0.7. The complete description of the screws I removed from my Series I is Crosspoint Ovalhead countersunk M4 x 0.7 by 20mm.
I lost one during a repair of my fuse panel, so I replaced them with flat countersunk socket head cap screws from the local hardware store. Mechanically, they worked fine but if you are not using the OEM radio finisher, the screws may put the panel under tension. A previous owner removed the finisher when he changed out the radio and it ended up splitting the panel in two near the fresh air vent.
If you can't find the exact screws in black, you might consider using button head cap screws that come blackened and won't put tension on the panel as the countersunk screws do. Regular steel screws can be blackened with Birchwood Casey Super Blue found in any sporting goods store that handles gun supplies
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
