They do pop up on Ebay, here you go http://www.ebay.com/itm/Nissan-240Z-260Z-280Z-Interior-Tail-Light-Panel-70-78-/190576522722?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3A240Z&hash=item2c5f3ef5e2&vxp=mtr it might take you a few visit to get them, happy hunting ;)
Edited by 72 OJ
https://www.classiczcars.com/topic/44648-interior-panels/#findComment-403979
Why not check with our site sponsors as they will have EVERYTHING you need instead of waiting for the right item on ebay?
That panel would only be 3 dollars cheaper doing their buy it now, than from Motor Sports Auto who help support this site.
Additionally, that panel in the auction has questionable tail-light access panels, they don't look right. The shininess of the plastic also leaves me with doubt.
Here's a link to Motor Sports Auto's on-line catalog of the interior parts for the rear of your car.
http://www.thezstore.com/page/TZS/CTGY/SIC07
In addition to being able to get everything from ONE source, you'll know that they'll fit together and if you have any problems that you can contact them and they'll make it right. They'll also be able to sell you the rivets you need to mount them. (The photo for the tail-light panel shows the fasteners in a bag.)
Doubt the auction includes them in the above e-bay sale.
You can find bargains on e-bay, but it takes time and patience to sort and sift through all the garbage as well as the over-priced items or items with outrageous shipping charges.
Sometimes what you "save" in $ turns into a large pain and expense that eventually costs you more than what you saved. And then doesn't look right.
FWIW
E
Edited by EScanlon
https://www.classiczcars.com/topic/44648-interior-panels/#findComment-403987
Olzed, are you referring to the auction or to MSA?
MSA does differrentiate between the 70-73 and 74 and later.
Don't forget that in the US, we only had the 260 for one year, 1974, while you had it for severral more.
In fact, if memory serves, your first introduction to the 280 was the ZX model, or am I wrong?
FWIW
E
https://www.classiczcars.com/topic/44648-interior-panels/#findComment-404012
Has anyone ever tried to make their own? Looks like they are just hardboard covered in vinyl.
Jack, the hardboard is shaped so I doubt that most guys with garage skills would or should attempt it. But there is a guy in the Bay area in California who has recreated the hardboard section in fiberglass. Strictly510 is the name of the business but I don't think he is web based. He hangs out mostly at HybridZ and his screen name is Rayven something... I used that method and here are the pictures...
First, you have to cannibalize a pair of doors for the metal tops. Then, you rivet the metal top to the fiberglass panel. At this point, you test fit to the door and drill holes and router them to the proper shape. I used some GM plastic panel rivets to attach the panel to the door. Finally, once you have everything drilled, you apply the vinyl and rivet the fuzzy to the window side. Not that hard but more expensive than buying new panels which as has been said, pop up from time-to-time...
Cost:
Fiberglass panels - $250 + shipping
Vinyl - $250 + shipping from Classic Datsun Motorsports
Various small costs include: upholstery foam, contact cement, rivets.
Edited by conedodger
https://www.classiczcars.com/topic/44648-interior-panels/#findComment-404103
Cost:
Thats more expensive than i thought...looks like ebay or MSA will be my friend
https://www.classiczcars.com/topic/44648-interior-panels/#findComment-404105
The items that Conedodger referred to were the Interior DOOR panels.
Those unfortunately, are hard to find in good condition... i.e. no speaker holes, no tears, snags, or puncture marks, and lastly, with the chrome strip still showing chrome. Additionaly the original hardboard is infamous for soaking up humidity (that's why there's a vapor barrier) as well as having the clip holes tear out of the edges when being removed. That's why the fiberglass backing is such a good deal.
Expect to pay UPWARDS of $400 or more dollars for a set of Interior Door Panels in good condition. In excellent condition.... probably double that.
Sometimes.... yes sometimes, a set will pop up on e-bay or Craig's list that is in good to excellent condition... then the bidding will go through the roof. Be sure to take a close look at any pictures as there have been surprises when the item gets delivered.
FWIW
E
https://www.classiczcars.com/topic/44648-interior-panels/#findComment-404108
  • Who's Online   1 Member, 0 Anonymous, 1,366 Guests (See full list)
